Want to build a pc before I go back to school, this is my first time trying to build a pc.
Budget (including currency): $650
Country: U.S.
Games, programs or workloads that it will be used for: Genshin impact, Apex, minecraft, Warzone, some video editing (cinematography) and school work
Other details: Im a casual player, play everyday for about an hour or two. Currently using a laptop just for work and some editing (though its starting to age). Would like to play 1080p high 60fps. I would like this pc to last as long as it can mostly because I can't get school work done at home on my laptop as it dies very frequently. Saved up almost a year but after pc parts started going up I decided to delay my build. If parts can be replaced for better ones at a similar price and if they are compatible please feel free to list your suggestions.
This list is just my rough sketch on what I could find that I think would be good.
CPU - Ryzen 5 4560G
Motherboard - Asus prime b550
RAM - DDR4 (2x8GB) 3600MHz
PSU - 500 watt thermaltake smart
Case - Darkflash DLM22
Not too sure on if I could put a GPU in for this budget/ build but would like to, not too sure on storage either.
https://linustechtips.com/topic/1362857-first-time-build-need-help/
https://pcpartpicker.com/list/mntgGq
The 5600g is cheaper. I changed the motherboard to support bios flashback. It has WiFi, and if you didn't need WiFi, you could step down to the non wifi model. This would save the $20 to bring it back down to your budget. I added a 500 gig M.2. At this price and with what GPU prices are right now, you'll struggle to fit a GPU in this build. Better off saving for when the prices go back to normalish.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
The TR Smart is horrible.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor  ($259.00 @ Newegg)
Motherboard: Asus TUF GAMING B550M-PLUS (WI-FI) Micro ATX AM4 Motherboard  ($157.66 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($93.99 @ Amazon)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Newegg)
Case: Cooler Master MasterBox NR400 (w/ODD) MicroATX Mid Tower Case  ($57.60 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Newegg)
Total: $673.23
Generated by PCPartPicker 2021-08-06 20:56 EDT-0400
geometry is hard
b550 > x570
