Hello.
I have HP pavillion 17 laptop and it stopped charging. I tried to re-plug charging jack to motherboard and it started to charge but then after fully charging laptop it stopped again. Will replacing charging jack fix the issue or could the problem be somewhere else.
Thank you.
https://linustechtips.com/topic/1362835-laptop-not-charging/
It could be the charger, the port, the battery, or worst, a fault on the charging circuit.
Or a combination of any of the above.
Case - Phanteks Evolv X | PSU - EVGA 650w Gold Rated | Mobo - ASUS Strix x570-f | CPU - AMD r9 3900x | RAM - 32GB Corsair Dominator Platinum 3200mhz @ 3600mhz | GPU - EVGA nVidia 2080s 8GB  | OS Drive - Sabrent 256GB Rocket NVMe PCI Gen 4 | Game Drive - WD 1tb NVMe Gen 3  |  Storage - 7TB formatted
Cooled by a crap load of Noctua fans and Corsair H150i RGB Pro XT
https://linustechtips.com/topic/1362835-laptop-not-charging/#findComment-14916401
On 8/7/2021 at 2:47 AM, corbax said:
no it does not power on. battery is 3-4 months old. first when problem occured after wiggling charger cable a bit it started to charge
Do you have a spare charger? If not I'd say 80% chance of being the port, but I recommend testing it just to be sure.
https://linustechtips.com/topic/1362835-laptop-not-charging/#findComment-14919891
I dont think it is related but i just want to say problem ocurred after i changed my ram stick from 8gb 2400mhz to 8gb 2666mhz. I was changing it cuz i was getting faulty hardware corrupt and somethink like tried to write to read only memory bsod (and one more but i just cant remeber it (i am sorry) but google said it could be connected to ram. I also got internal power error bsod witch might be connected to my problem
https://linustechtips.com/topic/1362835-laptop-not-charging/#findComment-14922853
