Budget (including currency): Max $1500
Country: USA
Games, programs or workloads that it will be used for: This is going to be used for Graphic Design so i will be using Adobe Illustrator, Photoshop, Blender, etc. This will need a large amount of memory to run these programs and get good results
This is the part list i currently have. I have a little knowledge on computers but not enough so if anyone can help that would be great. I am also looking for around 64GB of Memory with room for more in the future. For a graphics card, i have no clue what would be good for my workload. Any help would be great. Thanks!!
https://linustechtips.com/topic/1362092-graphic-design-computer-build-help/
Country: USA
Can you link the part list?
Copy the link right above the CPU, not the URL at the top.
On 8/3/2021 at 10:50 PM, Somerandomtechyboi said:
I think you will only need 32gb for now and upgrade the cpu to a 5600x
PCPartPicker Part List: https://pcpartpicker.com/list/jFGvrr
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor ($426.99 @ B&H)
Motherboard: Gigabyte X570 I AORUS PRO WIFI Mini ITX AM4 Motherboard ($209.99 @ B&H)
Memory: G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($142.99 @ Amazon)
Storage: Samsung 970 Pro 512 GB M.2-2280 NVME Solid State Drive ($159.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 1660 Ti 6 GB OC Video Card ($599.00 @ Amazon)
Case: Zalman S2 ATX Mid Tower Case ($52.99 @ Newegg Sellers)
Power Supply: Rosewill HIVE 750 W 80+ Bronze Certified Semi-modular ATX Power Supply ($69.98 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($139.88 @ Other World Computing)
Total: $1801.81
Generated by PCPartPicker 2021-08-05 00:25 EDT-0400
Get a used gpu, anything with ti or Vega in the name will do fine. I like quadros, a p1000 will do the job surprisingly well, a p2200 will do it better
I can somewhat agree but with some of these programs like blender it is recommended to have 32GB as a minimum so i might try and set the bar high and go from there
