NEEEEDDD HELP!!!!!
Solved by Hygel,
If it's only happening when you play games then you probably just have a bunch of bloatware set up to run when you're playing. Things like overwolf extensions or clipping softwares can pile up pretty easily. Try setting task manager to show you what's taking up the most cpu power and enabling "always on top" in the options tab (or just put it on another monitor if you have one), then boot up whatever game you're trying to play and see what it is rather than just looking at it while you're at idle. Try ending the tasks that you see start to rise to the top (except the game, obviously) and see if that works
