I need help with a PS5 and a Sony soundbar
blinq
So I'm facing a problem with audio from a PS5. I have a Sony HT-CT290/291 which only has USB, HDMI Arc and Optical Out. I'm planning to get a gaming monitor which only has 2 HDMI ports and one AUX port. What should I do to connect my PS5, monitor and soundbar? Should I use an HDMI splitter or an optical to 3.5mm from the soundbar to the monitor? Is it at all possible or should I just ditch the gaming monitor and get a classic TV?
  • 2 weeks later...
Is your monitor HDMI 2.1 or HDMI 1.4/2.0? I don't know as of today whether HDMI 2.1 splitter exist, so that being said I'll assume you play PS5 at 1080p/4k 60hz.
You would probably need HDMI splitter, one output goes to your monitor, and another output would then need HDMI to optical converter then the optical cable goes to your soundbar. The reason you can't use HDMI to soundbar is it require HDMI ARC to work which monitors don't have. Don't take my word for it as I didn't test this myself, and getting TV would be more hassle-free.
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ SE AMD RADEON 6900XT (Undervolt to 1045mV) | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: CORSAIR SABRE PRO WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
