Budget (including currency): around 2k us can move number a bit if it's worth it
Country:US
Games, programs or workloads that it will be used for:  gaming mainly I switch games alot but anything from simulators to fps  and some school work on it
Other details : I currently have a 3 year old msi laptop that still works pretty good but the heat just kills it and I like playing at a desk over on my lap. I have 2 monitors but they are both old and cheap so will run two but only need to buy one good one for the main monitor I have a key board and mouse that I could upgrade but will work for now. I also like rgb and water cooled if I can make it work with the budget
https://linustechtips.com/topic/1359055-first-build/
Here is a list: https://pcpartpicker.com/list/Y8vnz7
     This list will work great for everything. I managed to include a Logitech G Pro and a Mechanical keyboard with a 1440p 144hz monitor within the budget. If you want a better GPU, you can wait to upgrade your peripherals until you have some extra cash. Let me know if you have any questions.
https://linustechtips.com/topic/1359055-first-build/#findComment-14889595
  • 2 weeks later...
Thanks I will take a look... and ya im pretty new at all this so learning as I go I just want something I can upgrade as it gets older but soemthing that will play games now well and of course look really cool
https://linustechtips.com/topic/1359055-first-build/#findComment-14908208
