What you're looking for is an AM4 backplate. I don't know what vendors you usually use in Norway for computer parts but on Amazon.se I see there are plenty.
https://www.amazon.se/s?k=am4+backplate&ref=nb_sb_noss
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1358726-need-help-asap/#findComment-14887332
which one of these are suitable for the nzxt or is it just whichever?
https://linustechtips.com/topic/1358726-need-help-asap/#findComment-14887578
