Budget (including currency): Something preferably less than $200
Country: United States
Games, programs or workloads that it will be used for: Video editing and rendering/ mainly Gaming
Here is my current PCpartpicker list: https://pcpartpicker.com/list/m97rkX
I will prob buy everything soon
I am wanting to go for 144 hz 1440p
I am wanting advice mainly on my motherboard. I am not sure if I have made the right choice. LMK if the motherboard budget is too low for my system, but I want to preferably be less than $200. Onboard WIFI would be convenient for my setup.
Thanks for the advice!
https://linustechtips.com/topic/1358718-mobo-advice/
Mobo is fine.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1358718-mobo-advice/#findComment-14887234
4 minutes ago, Tangerine3 said:
Would it be the most efficient on my build? Am I fine? Or am I spending too much
If you're mobo is about 50% of the cpu, I wouldn't say you're spending too much. With that said you can always go with the MSI MAG B550 TOMAHAWK
instead save about $60. Although, at your budget, it's pretty negligible. You might need a better cooler for a 3900X: something like the Scythe FUMA 2 is always a go to for a good value cooler, or good old Noctua NH-D15 is always a good choice. At your current price point, it might be worth looking at 5900X. Although, I don't think you'll see much of a performance difference between the two.
https://linustechtips.com/topic/1358718-mobo-advice/#findComment-14887271
My one concern with the MSI mag B550 is that it doesnt have onboard wifi. I am unexperienced so I wouldn't be unreasonable to get that board I just don't know what are some good options in the way of WIFI connectors. Any reccomendations on that front?
Also, $60 is a fair price save for me. I have a big budget but I am not rich. I have just saved up for awhile.
https://linustechtips.com/topic/1358718-mobo-advice/#findComment-14887364
The MSI B550 Gaming Edge wifi is cheaper. It will cope with any current Ryzen cpu.
https://pcpartpicker.com/product/2f4BD3/msi-mpg-b550-gaming-edge-wifi-atx-am4-motherboard-mpg-b550-gaming-edge-wifi
https://linustechtips.com/topic/1358718-mobo-advice/#findComment-14887369
