1 minute ago, TheDeviser said:
Hello! I have just finished my build, booted into Windows and I have seen thtat my cpu is running pretty hot in idle (40-60 degrees). Is it normal?
Build: H510 elite with stock fans & R7 5800x & Noctua NH-U12S
I have applied the thermal paste myself.
What are the temps under full continuous load?
https://linustechtips.com/topic/1357782-cpu-running-hot/#findComment-14880838
That sounds completely normal, especially with that case using air.  Completely normal for Ryzen 5000.
As for a full load, Cinebench is an easy go-to these days.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1357782-cpu-running-hot/#findComment-14880849
Just now, TheDeviser said:
how should i test it? will league's practice tool do?
No, Use Prime95 with SmallFFT algorithm since it will put an unrealstic load on your CPU. If it doesn`t overheat there then it won`t in other applications/regular use
https://www.mersenne.org/download/
https://linustechtips.com/topic/1357782-cpu-running-hot/#findComment-14880850
In Cinebench R20 didn't go higher than 90
https://linustechtips.com/topic/1357782-cpu-running-hot/#findComment-14880862
Your case is bad, VERY bad, It has no airflow at all, replace the case for something with a mesh front, and you likely will be fine
https://linustechtips.com/topic/1357782-cpu-running-hot/#findComment-14880930
