Simple.
Micro ATX form factor, FM2+, nice looking case with high 3.5" hard drive storage (5+ slots)
Processor (needs onboard graphics, richland)
Case
Motherboard
PSU
Memory
I think that's all I need besides the drives.
P.S. CHEAP AS POSSIBRUUUU
Available from 3pm to Midnight Eastern Time (GMT-5). (>'-')> <('-'<) ^(' - ')^ <('-'<) (>'-')> You can't stop the kirby dance.
4770k | Gigabyte GTX 970 Mini | Lian Li PC-TU100B | MSI Z87I 2x8GB G.Skill Sniper | Noctua NH-L9i Silverstone Strider 450W SFX | Windows 10 | 2x 250GB 840 Evo Rad 0 1x 1TB WD 2.5" | 25% gaming, 25% CAD and rendering, and 50% web browsing.
https://linustechtips.com/topic/135771-help-build-a-nas/
the fractal design node 304 is a good choice for a NAS but it is not that cheap
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/135771-help-build-a-nas/#findComment-1805571
Simple.
Case
Motherboard
PSU
Memory
Check this out for more information on how to build your own NAS, they talk about all the important things that a nas needs.
PCPartPicker part list: http://uk.pcpartpicker.com/p/3mnvv
CPU: AMD A8-5500 3.2GHz Quad-Core Processor  (£66.99 @ Amazon UK)
CPU Cooler: Arctic Cooling UCACO-AP60301-BUA01 Fluid Dynamic Bearing CPU Cooler  (£8.62 @ Amazon UK)
Motherboard: MSI A88XM-E35 Micro ATX FM2+ Motherboard  (£40.15 @ Amazon UK)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory  (£55.00 @ Amazon UK)
Case: Fractal Design Arc Mini MicroATX Mini Tower Case  (£54.84 @ Amazon UK)
Power Supply: Be Quiet 350W 80+ Certified ATX Power Supply
Total: £225.60
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-04-05 15:29 BST+0100)
I know its UK prices but components can be found in most places:
Fractal Arc Mini has 6 3.5inch drive bays is chaper than node 304 aswell
motherboard has plenty of sata 3 ports (8)
cpu is cheap, has on board graphics and low tdp
cpu cooler is cheap and i only put it there because amd stock cooler is loud and annoying
4gb of ram is fine, but better value when you buy 8gb
psu is enough for that system and a couple of drives.
if you wanted to save more money downgrade cpu an a4 is about half the price of that a8, 4gb ram will drop almost half, plenty of value cases with no cable management,
finally alot of people recommend wd reds
https://linustechtips.com/topic/135771-help-build-a-nas/#findComment-1806776
Price breakdown by merchant: http://uk.pcpartpicker.com/p/3mnvv/by_merchant/
Benchmarks: http://uk.pcpartpicker.com/p/3mnvv/benchmarks/
Total: £225.60
http://pcpartpicker.com/p/3mopw
https://linustechtips.com/topic/135771-help-build-a-nas/#findComment-1806863
