So I got a laptop from a friend,
HP Envy M6, A10 cpu good for a notebook, but can't install the graphics drivers, dual graphics!.
Amd Radeon HD 8650G and 7600M dual graphics, been looking for about 6 hours now every driver download I have done has not worked, Every time it tells me to reset the laptop after install I get error code 34 on both gpu drivers in device manager amd mobility center keeps saying no gpu drivers installed 🤬...
So is there any way to fix this as it's doing my head in, currently running 8.1 what came with the laptop.
Haven't done a bios update no idea how, and chipset drivers are installed.
Please help me gods of problem solving!!!
https://linustechtips.com/topic/1357386-gpu-problem-on-laptop/
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1357386-gpu-problem-on-laptop/#findComment-14878491
5 hours ago, rickeo said:
ah that's good to know, If you can get some links it would be super appreciated! 16 hrs now just looking for the drives, 56 install fails!
https://linustechtips.com/topic/1357386-gpu-problem-on-laptop/#findComment-14878796
6 hours ago, rickeo said:
ah that's good to know, If you can get some links it would be super appreciated! 16 hrs now just looking for the drivers, 56 install fails!
https://linustechtips.com/topic/1357386-gpu-problem-on-laptop/#findComment-14878797
