Laptop temps question
Go to solution Solved by Helpful Tech Witch,
It’s fine. Laptops run hot, it’s what they do.
unless it’s pushing over 100cits going to be fine
I have an 8 year old laptop that when I bought new was used for architectural modelling and rendering. It is now quite outdated even for gaming. I now plan on using it to host a minecraft server. However, at idle, temps sometimes spike to 77c, but hover around 48-55 usually. Room temp in the summer right now is at 24-27c. I'm not sure what I can do to keep the temps down when I do get the server up and running. Suggestions?
TIA.
Specs:
Cpu: Intel i5-3230M
Gpu: Geforce GT 740M
Ram: 12 GB DDR3 1600MHz
HP Envy 17" Laptop
https://linustechtips.com/topic/1357060-laptop-temps-question/
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1357060-laptop-temps-question/#findComment-14876045
