Budget (including currency): $2000
Country: United States Of America
Games, programs or workloads that it will be used for: Blender, Premier Pro, Fortnite
Other details Im aware that my cooler on the list is a NZXT AIO I just haven't chosen a AIO cooler which is mainly why im asking for help, im looking to run fortnite at 200+ I would love if anybody gave reccomendations on what parts I should swap out and what AIO I should use also the nzxt case I have on the list is $150 but im getting it for $60 which is a decent deal thus the reason I put it up their It has bad airflow but I can manage. Thanks! https://pcpartpicker.com/list/72XnfP
Edited by SippyCup45
I mistyped
https://linustechtips.com/topic/1355839-first-time-builder-pc-build-help/
https://pcpartpicker.com/list/mB8jz7
I've gone for a more reasonable motherboard, it shouldn't be more expensive than the cpu
I also added an Arctic Liquid Freezer II 240 A-RGB, so you have that RGB but don't pay the overpriced NZXT one.
I also opted for the Seasonic semi-modular PSU, since you will be using all the pre installed cables and are now modular for other ones.
https://pcpartpicker.com/list/nQF47X
This would be an alternate build with AMD, in my opinion the better option, simpy better value for better performance even
Ram is still overpriced, and the case is still terrible.
geometry is hard
b550 > x570
I would still change the case. Will perform badly thermally either way.
geometry is hard
b550 > x570
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  ($589.99 @ B&H)
CPU Cooler: ARCTIC Liquid Freezer II 360 A-RGB 48.8 CFM Liquid CPU Cooler  ($166.99 @ Amazon)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  ($149.99 @ Newegg)
Memory: Silicon Power XPOWER Turbine RGB 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($84.97 @ Amazon)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($104.99 @ Lenovo)
Video Card: NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card  ($700.00)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply: MSI 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.88 @ Amazon)
Total: $2006.80
Generated by PCPartPicker 2021-07-12 14:18 EDT-0400
Better overall list IMO. has a 3080 + 5900x which will perform significantly better in every game including fortnite. Still has lots of RGB.
geometry is hard
b550 > x570
