Hello, I started seeing red dots(small to medium sized paint brush) appearing at random intervals and random places while gaming at different games but still works without a problem.
Is this a sigh that my GPU is saying has had enough ?
  • Finished ? It'll never be finished. A battle isn't like some stupid argument. As long as someone's still breathing, the fight isn't over. Everyone who searches for power without exception searches for battle. Do you fight in order to become more powerful ? Or you want more power in order to fight ?
https://linustechtips.com/topic/1355433-red-artifacts/
9 minutes ago, Fasade said:
Hello, I started seeing red dots appearing at random intervals and random places while gaming at different games but still works without a problem.
It can be, but it can also be a bad monitor cable.
https://linustechtips.com/topic/1355433-red-artifacts/#findComment-14863961
The cable is brand new that came with my monitor 5 months ago, so I didn't consider it.
https://linustechtips.com/topic/1355433-red-artifacts/#findComment-14863963
I've had plenty of problems with cables and sockets, especially in the monitor itself.  HDMI is especially bad as its only friction fit so can work itself loose over time.  Displayport I've found a lot more reliable.
That said, one of the Displayports on my GPU has gone bad and the HDMI is loose (I have swapped it over a lot) so I sometimes have to re-seat the cable to get a picture.  But in the past I've had random pixels on the screen too if its just barely holding onto the signal.
https://linustechtips.com/topic/1355433-red-artifacts/#findComment-14863971
I forgot to mention that the dots are a small to medium paint brush size and I am on display port.
https://linustechtips.com/topic/1355433-red-artifacts/#findComment-14863973
If they are bigger than a single pixel then that IMO points more to a GPU problem.  😞 Signal problems generally cause individual pixel errors.
https://linustechtips.com/topic/1355433-red-artifacts/#findComment-14864046
