Budget (including currency): 16,000
Country: California
Games, programs or workloads that it will be used for: streaming VR making videos editing games from vrchat and probably cold war
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Im upgrading from a console i will be buying a pre-build from cyberpower pc because of the customization opinion , 4K resolution (3840 x 2160) or higher is required  refresh rate 144 Hz
i need a very amazing headset that is comfortable and maybe noise canceling, a good keyboard definitely light up. i need really good webcam. i need a comfortable gaming chair hopefully one that can last for hours of game-play. a 144 Hz monitor 3 of them.and also and really good mic noise canceling audio adjustable.
https://linustechtips.com/topic/1355041-need-help-with-deciding-my-pc-setup/
