Budget (including currency): 2,000 USD
Country: USA
Games, programs or workloads that it will be used for: playing and streaming COD, Valorant, Minecraft, Phasmophobia, FNAF, CSGO
https://pcpartpicker.com/list/sFNG8J
Is this build balanced? Is there anything I should change? Is the incompatibility issue with the motherboard and the cpu something I should worry about?
https://linustechtips.com/topic/1354978-first-build-opinions-needed/
1. Buy Windows 10 Home instead of Pro, unless you will actually use the features of Pro.
2. The 980 Pro is overpriced as fuck. Get an SN550 or Sabrent Rocket Q instead.
3. Trident Z Royal is also really expensive. T-Force Vulcan Z will have a slightly lower CAS latency (which is better) and $50 cheaper for the same speed and capacity.
4. Power supply is overkill. This is more of a 650W system, unless you did that for future upgradeability.
This is a balanced system overall. You could probably bump down to a 10600K and still be more than fine, but the 3060 Ti is a solid card and the 10700K leaves you plenty of room for future GPU upgrades.
3. Trident Z Royal is also really expensive. T-Force Vulcan Z will have a slightly lower CAS latency and $50 cheaper for the same speed and capacity.
also, for some reason the hard drive is 180 dollars?!?! Here is the one they should get https://pcpartpicker.com/product/mwrYcf/seagate-barracuda-computer-2-tb-35-7200rpm-internal-hard-drive-st2000dm008
980 pro is pcie 4.0 and the 10700k doesn't even support pcie 4.0
Finally, the 212 evo will probably be a little bit weak for the cpu they are going to get, I would get a Scythe Fuma 2 https://pcpartpicker.com/product/YsHRsY/scythe-fuma-2-5117-cfm-cpu-cooler-scfm-2000
Holy shit, how did I miss that? Paying that much for a 2TB HDD is criminal!
I was also going to say this, but honestly if OP is fine with sort of high noise, it will be fine. The Fuma 2 is a great choice though, only a little more expensive.
Got it, thanks. I'll look into that ram and the wd ssd's.
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  ($589.99 @ B&H)
CPU Cooler: Scythe FUMA 2 51.17 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  ($149.99 @ Newegg)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($74.99 @ Newegg)
Storage: Samsung 980 1 TB M.2-2280 NVME Solid State Drive  ($119.99 @ Adorama)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($55.49 @ Amazon)
Video Card: NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card  ($700.00)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($84.99 @ Amazon)
Power Supply: MSI 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($118.88 @ Amazon)
Total: $1954.31
Generated by PCPartPicker 2021-07-09 10:49 EDT-0400
geometry is hard
b550 > x570
If I get the hard drive I picked for 50 bucks off newegg, is it okay? Also, could you send a link to a ssd you recommend? thanks
If you get a 7200 RPM 2TB drive for $50, it is quite reasonable, I would go ahead and purchase.
I would recommend an SN550 https://pcpartpicker.com/product/BhmFf7/western-digital-blue-sn550-1-tb-m2-2280-nvme-solid-state-drive-wds100t2b0c (currently out of stock on newegg but in stock on amazon)
Thanks a bunch
Total: $1954.31
thanks a bunch, i'll definitely consider this
thoughts on the cooler master master air ma410m?
Total: $1954.31
This is a really good list for your needs cause you stream
Not gonna make a pcpartpicker of my own cause i dont see any major improvements that can be made other than 4tb hdd and a cheaper mesh case but those are just minor improvements .-.
