PC part list
Pc part picker says 'Some AMD B550 chipset motherboards may need a BIOS update prior to using Vermeer CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.' is this a going to be a problem? How can i lower the price on the motherboard without taking away any features? Is the power supply wattage ok?  Will the cooler be sufficient?
https://linustechtips.com/topic/1354665-i-need-some-advice/
2 hours ago, Ayan Rahman210 said:
PC part list
Your parts list is private.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1354665-i-need-some-advice/#findComment-14859022
