Hello,
My laptop screen started going black for no reason, and I thought it's only going to be black for a second because it happened to me last time but it was for a short time only. But, when it black screen yesterday it was long.
I was only on a Zoom meeting and watching YouTube. When I tried to wait, It didn't go back normal I tried to shut down/restarted my computer by finding the windows button and, somehow the screen goes back when I click off the windows start menu, It goes black again... Somehow on the 2nd try, it goes normal but, the screen is glitching on the desktop the name and icon was flickering but somehow my cursor is perfectly fine. and not glitching, when I finished looking what's going on. I restarted my pc, and my screen went black again. I only have one choice but to hold the power button in 6 seconds. to force shutdown.
And today, my pc suddenly went slow. I tried to play some Valorant and Hell it was very very laggy i was getting 1-20 fps I had to quit it because I fell like my laptop is going to die. But normally I get 30-60 fps (average 50) I tried to scan for viruses, but it wasn't detected or nothing has found. What's the cause of this? And, is there any I can do to fix this?
I have Intel UHD Graphics and, Nvidea GeForce Mx350
CPU Intel i3 10th gen @1.20 GHz max 3.37 GHz
Thanks,
Nerdesth
https://linustechtips.com/topic/1354548-graphics-problem/
1 hour ago, fuzz0r said:
Are your graphics drivers up to date?
Well, I recently Updated Nvidea drivers. But the results in GTA V it just crashes, and it didn't go through the game, it's just the loading screen and then crash. It took 2 times longer to load when I last played GTA.
https://linustechtips.com/topic/1354548-graphics-problem/#findComment-14858619
19 hours ago, fuzz0r said:
No worries.
If you want to try an earlier version, go here: CLICK.
Hey,
Something good happened. Windows automatically updated my pc and for my stupidity, I didn't check what kind of update was that, I just shutdown and update it because I thought the damage is hardware. Few hours later. I launched my laptop and The lag was gone I tried playing GTA V the loading is normal and it go through the game I played for an hour and nothing seems wrong. and it runs like I usually play with. I didn't played Valorant yet, I'll try later.
https://linustechtips.com/topic/1354548-graphics-problem/#findComment-14860519
20 minutes ago, Nerdesth said:
Hey,
That's fantastic. 🙂
Glad to hear it's fixed.
https://linustechtips.com/topic/1354548-graphics-problem/#findComment-14860550
