Do you still have the connector you cut off? if so just go off of that.
RJ-45 only utilizes 8 strands of cable where this is 12, are you sure the end of that cable was RJ-45 and not something else that's proprietary?
Data Systems Administrator | Sergeant - US Marine Corps | CCNA / SEC+
Ryzen 9 5950x | 64 GB DDR4 3600Mhz | Gigabyte RTX 3080 Ti | Full Build Info | HomeLab Setup
https://linustechtips.com/topic/1353522-rj45-cable-colors/#findComment-14850129
It’s out of a camera I will try and go to the end it was just water damaged. And yes it did come from a female RJ-45
https://linustechtips.com/topic/1353522-rj45-cable-colors/#findComment-14861837
Have you considered how you're actually going to fit the connector when normal tools will only do 8 pins?
https://linustechtips.com/topic/1353522-rj45-cable-colors/#findComment-14862465
