A family member bought a used GPU and it worked fine for 2 months but now it's having issues. So they asked me for help but I ran out of ideas.
Out off nowhere, the screen will freeze in whichever image it was showing, even though the rest of the computer will still be working, once this happens only hard-resetting the PC will work. After the hard-reset the GPU stops giving a signal even though the PC boots and gives no error messages at all it just doesn't give a signal out. To make it work again I had to take the GPU out, boot with integrated graphics and turn off the PC, put the GPU back in. It worked, until it froze again.
Now for the weird parts:
- when it is working I am able to test the GPU with Furmark, Heaven, Superposition and synthetic benchmarks for hours without any issue;
- the computer works just fine without the GPU, just can't game on it cause old CPU integrated graphics but it does everything else;
- the GPU takes all power from the PCIE slot so no issues with the PSU;
- it's not the monitor or the cables since I tested with mine and issue keeps happening;
- it happens with both the HDMI and DP ports, didn't try the DVI port because i don't have a DVI monitor, cable or adapter;
- the crash even happened when on the desktop and only with Discord app open.
The GPU is an ASUS RX 560 OC 2GB
My current line of thought is that the display out connectors might be damaged because of the rust on them (former owner lived near the ocean) even though the board itself seems fine.
Any ideas what could be causing this? How this could be fixed? He is trying to old on getting a new GPU until things calm down (for 1 year), hence why he bought a used GPU.
Thanks for any help or tips
https://linustechtips.com/topic/1351394-help-with-troubleshooting/
