Issue:
My PC randomly loses signal on both my HDMI and DP monitors, almost like it shut down instantly. Except the fans keep running and the LED on the power button stays on. After I click the restart button on my case, it restarts normally, except continues to instantly crash/lose display signal after booting usually like 2-3 times before it finally turns on and starts working until it randomly crashes again, can be a few days or a few hours. When I boot from normal shut down, it hasn't crashed once, but when I boot after a crash, it's never started working on the first try.
I'm not really sure what it could be, so I'll list my components and what I touched since this started;
Components:
PSU: Corsair RMx 850W (couple months old)
Ram: Corsair Vengeance 3000 mhz (running XMP for the last ~2 years)
Mobo: Asrock b450m pro4 (~2 years old)
GPU: EVGA RTX 3060 (couple months old)
CPU: 5 2600 (set it to 1.4V, 4100 mhz June 17th ~2 days before crashing)
7 Noctua NF-P12 redux 1700 PWM fans (one on a hyper 212 evo)
And using a Corsair Commander Pro as PWM fan hub, which plugs into 7 pin USB header
What I've touched since it started:
On June 17th, I set the 5 2600 to 1.4V 4100 mhz as I'm expecting a 3070 ti soon. That ran without issues for a couple days.
On June 19th, I received my 7 Noctua NF-P12 fans, replaced my 6 Corsail QL 140 fans and the stock fan on the Hyper 212 evo.
That required removing the GPU temporarily.
During the switch I did drop my Commander Pro, and it was hanging off the table for a few seconds.
Not sure if that could've potentially bent some pins in the USB header on the Mobo and if that could cause the crashes or not.
I also closed the back of my case - terrible cable management, required brute forcing it pretty aggressively, but it closed eventually. I took it off after the first crash though. Thought that could have something to do with it.
And I updated my GPU drivers to 466.77
Other than that, nothing's changed.
Some of the times it's happened:
Went to bed after that, and first crash happened evening of June 20th.
Couple days ago it crashed about 30 minutes into playing a VR game.
Today like 5 times in a row when I tried to load World War Z, in the menu. After crashing a bunch of times (each of those 5 crashes requires like 3 restarts with crashes before I can even load into the menu) - I was able to play for hours, then I played Cyberpunk 2077 for hours as well without crashes.
I also ran Heaven and userbenchmark for ages, temps never go above about 60ish on both GPU and CPU, and no crashes from the load...
Any ideas on what it could be? Unfortunately, I don't have an extra PSU/GPU/Mobo to test each seperately.
https://linustechtips.com/topic/1351172-pc-loses-display-randomly/
Im having the same issue, its only when i load into a 3D game tho. I can use Windows just fine but no games. I saw some one else with the same issue and he also had  an RTX card (I have RTX 2070 from MSI). Its so annoying and ive tried EVERYTHING: DDU, GPU reseat, AN ENTIRE PC RESET 🤦‍♂️, its just so annoying ; . ;. it was going for days without doing it then it just randomly did it. I can also run benchmarks just fine! (Furmark / Cinebench) its so weird 😕  So plz lmk if you find a fix 😄
Check reliability monitor, if theres a red x post details
Sounds like windows desktop manager or nvidias driver might be crashing.
Recently had that problem myself, and ultimately figured out it was the Xbox One X controller's bad fimware that was doing it.
System Specs: AMD 5950x PBO-AutoNoctua DH-15 Black | Gigabyte x570 MasterEVGA 3080FTW3 Ultra | (2x16gb) G.Skill Royal 3600mhz CL18 | Corsair 5000D Airflow (Black) Samsung 980 Pro 2TB & Firecuda 520 1TB & Crucial MX500 2tb850W Corsair RMX | 2 Noctua A14 CPU, 6 Noctua A12x25 Intake, 3x Noctua F12 Top Exhaust, 1x Noctua A12x25 Back Exhaust
Monitors: (Main) LG Ultragear 34" 2k Ultrawide 144hz IPS '34GP83A-B' (Side) Acer Predator 27" 2k 144hz TN 'Abmiprz'
Peripherals: Corsair K100 OPX | Logitech G502 Lightspeed | Corsair Virtuoso SE | Audioengine A2+
There's a lot of them, but just windows was not properly shut down and various programs stopped working, but no consistency. One's a setup/install, one's my phone, wallpaper engine, oculus app, etc.
that's.. not good.
I would start with updating firmware on the mobo, download the latest drivers for your peripherals too and check if the peripherals themselves are using the latest firmware.
Edit: In fact you should also download the chipset driver on your motherboards support page (after mobo firmware)
I would get a unused usb stick, put memtest on it and run that on a reboot, to make sure your ram isn't the cause.
Because inconsistent app crashing to the extent of my knowledge would either be A: Ram or B: Corrupt drive
Edited by Daethz
looked at asrock page, no other drivers really useful, just make sure mobo bios/chipset driver up to date
Are crashes only occurring on games or on heavy load in general?
I would also open the pc up and make sure all of the cables are fully plugged in, inspect them for any damage especially in places where they touch the case, and also make sure none of them are pinched too hard, I have seen people go way to far with zipties.
