I just recently finished my first pc build, and all works great...until I start gaming, where after around 10-20 minutes the screen goes black andI cant alt+tab or anything (the power on the pc remains on. I've kept an eye on my cpu and gpu temps, and neither go too high (when stress testing they only hit 75C max). My BIOS says my voltages are fine so I have no idea anymore.
SYSTEM SPECS -
i5 4670k OC@ 4.5GHZ
ASUS GTX 770
GIGABYTE SNIPER Z87
CORSAIR RM 750
G.SKILL Sniper 8GB RAM
SAMSUNG 840 EVO 256GB
2TB 7200RPM HDD
https://linustechtips.com/topic/135093-help-blackscreen-when-gaming/
do you have the latest drivers?
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
Try playing @ stock.
CPU: Intel i7 3970X @ 4.7 GHz  (custom loop)   RAM: Kingston 1866 MHz 32GB DDR3   GPU(s): 2x Gigabyte R9 290OC (custom loop)   Motherboard: Asus P9X79
Case: Fractal Design R3    Cooling loop:  360 mm + 480 mm + 1080 mm,  tripple 5D Vario pump   Storage: 500 GB + 240 GB + 120 GB SSD,  Seagate 4 TB HDD
PSU: Corsair AX860i   Display(s): Asus PB278Q,  Asus VE247H   Input: QPad 5K,  Logitech G710+    Sound: uDAC3 + Philips Fidelio x2
HWBot: http://hwbot.org/user/tame/
