Do you mean this guide ? PEP 8 -- Style Guide for Python Code | Python.org
The bottom of the page has a link to .txt  (markdown) format of the page : https://github.com/python/peps/blob/master/pep-0008.txt
You could just say Print to PDF if you have some virtual printer ... ex pdf24.org or whatever (Microsoft print to pdf)
You could use Developer Tools in your browser to disable/delete everything outside the content and save to HTML or PDF
I did that and saved to html and then ran the HTML through adobe acrobat pro to create PDF from it .
See the html and pdf files here PEP 8 -- Style Guide for Python Code Python.org.pdfPEP 8 -- Style Guide for Python Code Python.org.htm
https://linustechtips.com/topic/1350921-pep-8-guide/#findComment-14831663
Yeah after posting this post I figured out my self lol. Thank you!!!
https://linustechtips.com/topic/1350921-pep-8-guide/#findComment-14833654
This is the best way to show case pep8
https://www.youtube.com/watch?v=hgI0p1zf31k
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/1350921-pep-8-guide/#findComment-14838579
