Intel Core i7 3770k @ 4.4 GHz - H100i # Asus Sabertooth Z77 # Gigabyte GTX 670 Windforce 3 @ 1202Mhz
Samsung 830 128GB SSD # 16GB Corsair Vengeance 1600 MHz
CPU-Z Validation
https://linustechtips.com/topic/13509-cheap-good-power-suply/#findComment-145541
no such thing as a cheap power supply in my book
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/13509-cheap-good-power-suply/#findComment-145561
Get the FSP...personally i would only buy corsair above the GS Series. And even then i probably wouldn't.
Since i doubt you need 400 Watt, 350 Watt are probably enough if you can wait a little bit...get something good, like this one http://geizhals.de/eu/fsp-fortron-source-fsp350-60egn-90-350w-atx-2-3-a673753.html (It lists all vendors in europe)
I installed this one i a couple of PC's and they are all working flawlessly and use very little power. One has an Athlon 750K and a HD7870 build in. It only draws about 190 Watts from the wall with one SSD and 8 GB of 1,5 Volt DDR3
Good news everyone...!
https://linustechtips.com/topic/13509-cheap-good-power-suply/#findComment-145660
