What VESA Mount Should I Get?
GenericBot1
Hey guys, I'm looking for a VESA mount so I can mount my new LG 27GL83A and my original monitor the LG 29UM67P. I want to mount the 29UM67P vertically as I don' have the space to put both monitors horizontally. I'll put the links to both of the monitors below if you need a picture of them. I don't know a whole lot about monitors and VESA mounts so any suggestions would be greatly appreciated.
83A: LG 27GL83A 27'' UltraGear™ QHD IPS 1ms Gaming Monitor with G-Sync® Compatibility (27GL83A-B) | LG USA
67P: LG 29UM67-P: 29'' Class 21:9 UltraWide® IPS LED Monitor (29'' Diagonal) | LG USA
Anything really gonna work imo, those 2 only weighs about 10kg (22lbs) and all youll need is a vesa mount that supports both 75mm and 100mm on its description.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
