You didn't specify which ASUS B450 motherboard you have, but in general the pins for the power switch, reset switch and front panel LEDs are always in the bottome right corner of the motherboard. There is also a section in your motherboard's manual dedicated to the front panel header.
Here's an example:
Where do I plug in my front I/O cables on the Asus B450 F motherboard? -  Quora
