3 minutes ago, tete said:
My GPU is only using over 30% in Apex Legends.
And the temperature is around 50 only.
The game only gonna use the amount of resources it needs. This is super super normal.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1348454-low-gpu-usage/#findComment-14811476
You're likely playing at 1080p, which puts more stress on the CPU, and it's not a great CPU to begin with, further hindered by the very slow RAM, running in single channel. In other words, you're bottlenecked.
Edited by Chris Pratt
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1348454-low-gpu-usage/#findComment-14811729
so, should I get more ram??
https://linustechtips.com/topic/1348454-low-gpu-usage/#findComment-14815418
Replacing your current RAM with a kit of 2x8GB 3200MHz CL16, at least, will help.
https://linustechtips.com/topic/1348454-low-gpu-usage/#findComment-14815729
