Budget (including currency): I guess 450 USD
Country: Egypt
Games, programs or workloads that it will be used for: I dunno. A lot of things.
So basically I already know what I will have but just to make sure, Im asking to upgrade if needed or something. Here's the components
Cpu: Ryzen 5 2400g (Gpus are hard to find nowadays so an apu is fine especially with vega 11, And the cpu is sold on ebay for 60 usd (used) )
Cooler: Thermaltake ux100
Ram: Patriot viper steel rgb 16gb (2x8) 3200mhz
Motherboard: Asrock B450 Pro4-F
Storage: Seagate barracuda 2tb hdd (I care about storage not loading speed because I'm patient)
PSU: Evga 100-Ba-0600-K1 600W
Case: Aerocool Cylon ATX Mid Tower Case
Case fan: Gim KB-23 Rgb 3 pack 120mm
https://linustechtips.com/topic/1347094-so-maybe-help/
With the caveat that I don't know what's available in Egypt (and I doubt anybody else does here either)...
Case front airflow appears to be almost nil and not a lot on top either. Not something I would pick for a system I intended to use for any length of time. That 3-pack of fans isn't going to do much.
The Thermaltake cooler probably doesn't perform much better than the one that comes with the 2400G but if you just want it for the RGB if it's only $20...
In spite of what you say about patience, I would implore you to get at least a small SSD for the operating system for general system responsiveness and save yourself the trouble of reinstalling/cloning later. You can get a 128GB SSD for the money you'd save by dropping the unnecessary CPU cooler, really.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1347094-so-maybe-help/#findComment-14800935
Im actually not only just egyptian but russian at the same time.
Yes, Its for the rgb ( At least it has cooling)
No, Storage are meant for storage. And Im patient af so no need for ssd
https://linustechtips.com/topic/1347094-so-maybe-help/#findComment-14800942
31 minutes ago, tenarom6_official said:
So, Do I need to upgrade anything?
you are lookin good with these stuff but, if you want a better pc I think you need to wait and be patient cuz in 2022 the prices will dropdown and you will have better specs for same or less price
https://linustechtips.com/topic/1347094-so-maybe-help/#findComment-14800972
