I dont know if this has anything to do with the fact i just recently installed the newest GeForce Game Ready drivers, but randomly while doing anything the display will turn black. Audio is still there, and fans stay at the speed they were at. This is the 3rd gpu I've had thats given me issues
what if im normal and you arent?
https://linustechtips.com/topic/1345758-display-randomly-going-black/
4 minutes ago, NeoFriction said:
I bought a gtx 650 a few months ago and this happened.Did you get a buzzing or an electrical sound while black screen.My GPU's chip fried.I give it to the manufacturer for repairs.
that happened to my last unit, there is no buzzing while it happens
Can you try to monitor your gpu and CPU temps.If no buzzing sound then go for the monitoring of your cpu.If the temps go too high the CPU starts thermal throttling.And a cpu in that state can't keep up with your GPU and it stops displaying anything.A GPU and a CPU work together,if any of them fail they can cause these issues.
alright, i have hwmonitor so ill keep an eye on my temps
