Budget (including currency): $1400-1600 NZD
Country: New Zealand
Games, programs or workloads that it will be used for: Web browsing, watching video/streams, some gaming, will be on 24/7, 365. Used to game mostly on PC but have decided to mostly use consoles where I can, would still like my PC to be decent for when its infeasible or more convenient than a console.
Other details: My current system serves me well (its an i5-4670k and has an RTX 2070 in it which I will just be swapping into the new build), but its fairly old, and I believe the PSU is failing. I considered just taking it in to get looked at/cleaned and the PSU replaced (if that is indeed the problem), but I also thought if I can just get a cheap enough new build, might wanna do that instead, so I went to where I usually get systems built and they quoted me the system below for $1410 NZD (includes Win 10 and labour).
Intel Rocket Lake Core i5-11400F
ASUS PRIME B560 PLUS
Corsair CMK16GX4M2Z3200C16 Vengeance LPX 16GB (2x8GB) DDR4-3200 CL16 Designed for AMD Ryzen
Seagate Barracuda 510 250GB PCIe NVMe SSD
Corsair Carbide 175R RGB Tempered Glass Mid-Tower Case
Silverstone ST65F-GS 650W Full Modular 80Plus Gold Power Supply
Is this system worth it for what I want? Are there any parts that are kind of crappy? Is it going to run well? My current system has a large heatsink and noctua fan which I've noticed is missing from this quote.
One thing I requested was that the system run fairly quite/silent when idle/browsing/watch video, will this be the case?
Another concern I had was the power supply, I've never had a Silverstone before, is it going to be reliable?
Oh also, its been a quite a while since I've done anything like this, but ram being designated as for team red/blue is new to me, is that going to be a probem?
Thanks.
https://linustechtips.com/topic/1339100-advice-on-build/
i would consider a different power supply such as the corsair rm, enermax revolution df, or msi agf. however, looks good to me, nice choices otherwise!
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1339100-advice-on-build/#findComment-14740759
Thanks.
I would change the power supply to be honest to Corsair rm, but everything else seems fine
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
https://linustechtips.com/topic/1339100-advice-on-build/#findComment-14740818
22 minutes ago, Ridguard said:
So there would be nothing wrong with that ram then?
And it should be quiet?
I just talked to a friend of mine about it, is it worth waiting for DD5 to be a thing, or not really?
While ddr5 is going to be a thing for the near future you don't have to worry about it since it's definitely required new cpu, mobo, chipset and of course ram, and your ram choice is definitely good, unless of course you mean to just wait for the whole upgrade until newer cpu that supports ddr5 come to the Market, and in that case i leave it to you and others
Are you really have the urge to upgrade or not...
https://linustechtips.com/topic/1339100-advice-on-build/#findComment-14740858
Its sort of up in the air, even though I'm pretty sure I have a PSU thats going bad, I'm not fully certain thats the problem. Its possible I could chance it and wait and be able to upgrade later without issue and sell my old system then, or it could go wrong. Or I could just get it looked at/replaced.
I realize this is probably a hard question to really answer, but is it likely I could get a similar powered build and price when ddr5 is a thing?
https://linustechtips.com/topic/1339100-advice-on-build/#findComment-14740926
To be Frankly honest, kinda is, because next gen ram technology almost always have very high starting point compared to let's say cpu and gpu, also there's a lot of rumor going on that alder lake (o think it was the name) was going to require atx12vo, so new type of psu standard which no one know how the price is going to compare against normal atx psu, i hope it didn't differ much...
Edited by Liam danu
https://linustechtips.com/topic/1339100-advice-on-build/#findComment-14741056
Alright.
From what I can gather, it's not really worth waiting on DDR5, now I just need to have a think on weather its really worth it to build new or fix up my old system.
I sent the same question about the ram back to them before I posted on here, they offered me G.Skill Ripjaws V 16GB (2x8GB) DDR4-3200 CL16 instead for no price difference. From what I can gather theres not much difference, but I'll take opinions.
https://linustechtips.com/topic/1339100-advice-on-build/#findComment-14741182
