PCPartPicker Part List
CPU: Intel Core i5-11600K 3.9 GHz 6-Core Processor  ($258.99 @ Newegg)
CPU Cooler: Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler  ($109.95 @ Amazon)
Motherboard: Gigabyte Z590 AORUS ELITE ATX LGA1200 Motherboard  ($219.99 @ B&H)
Memory: Team T-FORCE DARK Za 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($154.99 @ Newegg)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($92.99 @ Amazon)
Power Supply: Enermax Revolution D.F. 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Amazon)
Case Fan: Corsair AF140 (2018) 62 CFM 140 mm Fans 2-Pack  ($34.99 @ Amazon)
Custom: any 3080 ($700.00)
Custom: Windows 10 Pro Unactivated ($0.00)
Total: $1811.88
Generated by PCPartPicker 2021-05-17 22:23 EDT-0400
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1339082-help/#findComment-14740606
Total: $1811.88
Won't phanteks p400a/500a would be a better case?
https://linustechtips.com/topic/1339082-help/#findComment-14740663
Not really. The Phanteks ones are all probably excellent cases. I went with the 4000D (Edit: 4000D Airflow) because it is a very thoroughly reviewed case that many popular builders such as Gamers Nexus recommend. Also, I really like the look of it.
Nothing against Phanteks or anything. The P360A is my go to recommendation on a budget.
Edited by davemc
Big nerd.
https://linustechtips.com/topic/1339082-help/#findComment-14740670
