Dear community,
I saw that there was available a new intel graphics driver for my intel G2020 CPU and I thought I should install it.
When I did,the screen went black and then came back for a few seconds but then it went black again and I had to manually shut-down my PC.
Right now the only complaint I have is that there is no audio signal through HDMI and I still don't know if the driver has been succefully installed.
Today I reinstalled my windows and tried to install the driver again.Same issue,audio says goodbye and the installation is not reaching its end.
Please help,
Luca.
https://linustechtips.com/topic/133902-intel-hd-graphics-big-problems/
Dear community,
Please help,
Luca.
Remove the driver, and install the older version.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
I reinstalled the windows because it didin't let me simply uninstall the driver.I went from win8 to win8.1 and everything was ok at first.I got my old driver that I knew it works and everything seemed ok.It got some updates and I was forced to restart.After I restarted,it lost sound again.I unchecked the intel graphics driver from the update list but it seems like it wasn't that.Tonight i'm going back to windows 8 with the old driver and block the updates.Hopefully,everything it's going to be okay.
Shame on you,intel!
