So I have a prebuilt Alienware AMD version r10 ... this is the specs
cpu - AMD 5950 X
gpu - 3090 dell
memory - hyperdrive 3200mhz 16gb
storage - pcie m.2 1tb
I’m trying to get a constant 360 FPS .. on games but it’s dropping .. what can I do to get a constant 360 FPS .. do I need more ram or what ?
https://linustechtips.com/topic/1338391-please-any-advice-would-help/
cpu - AMD 5950 X
gpu - 3090 dell
More specifically FORTNITE
what games, what resolution, what monitor, what is your internet and what is it dropping to
also what settings in game
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
Just now, Dean0919 said:
Why 360?
cpu - AMD 5950 X
gpu - 3090 dell
human eye can only see 24 fps/s
Throw in some RAM to increase the RAM to 24-32 gigs. If you have a 5950X and a 3090, using 16 gigs of ram is stupid, as you have lesser RAM than your vram
What resolution and what settings are you playing at? Windows might be doing some unfuckery so that can be the cause too.
