Now is a terrible time to build a PC. If you're not in desperate need of one, I'd say hold off a little while longer.
Leonidas Specs: Ryzen 7 5800X3D | AMD 6800 XT Midnight Black | MSI B550 Gaming Plus | Corsair Dominator CL16 3200 MHz  4x8 32GB | be quiet! Silent Base 802
Maximus Specs: Ryzen 7 3700x | AMD 6700 XT Power Color Fighter | Asrock B550M-Itx/AC | Corsair Vengeance CL 16 3200 MHz 2x8 16 GB | Fractal Ridge Case (HTPC)
https://linustechtips.com/topic/1338350-building-first-pc/#findComment-14735232
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1338350-building-first-pc/#findComment-14735246
45 minutes ago, davemc said:
note that this is without graphics card, and if you are going for 600 w/o graphics card, this is a solid build.
However, if you are gaming you will likely need to allocate a few hundred more for a graphics card (you will have time to save up for it) or compromise other components to fit a graphics card in your budget
https://linustechtips.com/topic/1338350-building-first-pc/#findComment-14735308
PCPartPicker Part List
CPU: Intel Core i3-10100 3.6 GHz Quad-Core Processor  ($114.99 @ Walmart)
Motherboard: ASRock B560M-HDV Micro ATX LGA1200 Motherboard  ($83.98 @ Newegg)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($74.97 @ Amazon)
Storage: Team AX2 512 GB 2.5" Solid State Drive  ($50.99 @ Amazon)
Case: Cougar MG130-G MicroATX Mini Tower Case  ($39.99 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Newegg)
Total: $424.91
Generated by PCPartPicker 2021-05-15 22:27 EDT-0400
look on ebay for a used r9 290 or gtx 780.
https://linustechtips.com/topic/1338350-building-first-pc/#findComment-14735340
