Which monitor is better?
Nick123pc
Which of thise two monitors is better; lg ultragear 27gl83a-b or lg 27gn800-b?
From what I can tell they are both very similar. The only difference seems to be that the 800-b has a 'slightly faster response time and a lower 60Hz input lag' according to rtings.com (taking into account that the 83a-b and the 850-b, (which is the monitor RT compares the 800-b with,) are essentially identical panels.)
Honestly it probably just depends on which one is cheaper or which one has better reviews. If you haven't already try to watch as many reviews on YouTube for both panels!
For what it's worth though, I have the LG 27GL850-B and it's a sensational panel for the price. Both monitors you've mentioned are similar to mine, so I don't think you can go wrong with either! 🙂
CPU: AMD Ryzen 5800x RAM: Corsair Vengeance RGB PRO 32GB @3600MHz GPU: ZOATC RTX 3090Ti
MOBO: Asus ROG Strix X570-E NVME: Samsung 980 Pro 1TB Case: CM MasterBox TD500 Mesh PSU: Corsair HX1200W Platinum
PC Part Picker List
