What would work better
Solved by Pixelfie,
2 minutes ago, Hamzabrzi said:So the ram dose not play a big factor when playing games ?
It does make a difference but the CPU would be more important. If you plan on upgrading the CPU go for the 6500 since you don't need to buy new RAM.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
