Hey all,
So, I can't even take my filament out of my extruder. It keeps making this slipping sound whenever I try and take it out. I attached a video of the problem so you could understand it better. I have a Monoprice Select Mini Pro.
I am guessing the extruder can't grip my filament good enough or something..
Any help would be appreciated!!
https://linustechtips.com/topic/1335731-3d-printer-extruder-problem/
Noooooo, your hot end needs to be heated. Because if you don't the plastic will stick to the parts inside the hot end. Just heat it up to about 200 °C if you have a PLA filament or 230 °C if you have ABS filament. If you use anything different just look on the box for the recommended temperature. Everybody makes mistakes.
If you want to get into 3D printing, I would recommend you to watch some YouTube videos about 3D printing, you can learn a ton of things from those.
Thank you so much lol! Yes, I am trying to learn some things from a 3d printing book.
