Soo
Im stuck on a problem. I have been having fps drops in games like apex legends, rage 2, division 2 and even for some reason minecraft. All 4 games are running at low settings but im still getting frame drops.  Specs for my pc are:
case Titan 750
asrock h310cm-dvs
I5-9600k
nvidia gtx 1060 6gb
8gb 2666mhz xpg
1tb hdd segate
monitor is a viewsonic va1931 19" 1360x768p display with 5ms and 60hz
should i upgrade something from my specs or is it something else that i should do to get better frames?
https://linustechtips.com/topic/1335223-problem-with-fps/
<-- Moved to Troubleshooting -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1335223-problem-with-fps/#findComment-14712009
3 hours ago, tkitch said:
What're you getting for framerates?  At 720, your system should be able to pump out the frames, unless you've got something set up poorly.
One thing I'd suggest:  Buy a 256 or 512GB SSD and install windows on it, your box will get soooo much faster.
Frames are around 40 to 70, but drops to 7 are constant. Ssd is in the shipping, soo in a week ir two ill know
https://linustechtips.com/topic/1335223-problem-with-fps/#findComment-14712087
1 minute ago, tkitch said:
Have you tried a benchmark like heaven or Furmark?  See how the GPU runs?
Is it dropping clocks, etc?  How are temperatures?
Speed is normal when ive done benchmarks soo 1550ish. Temp sits around 70 to 82 degrees celsius. And when not under load then 47°c
https://linustechtips.com/topic/1335223-problem-with-fps/#findComment-14712125
