cooler master hyper 212 evo performance
I have a hyper 212 evo and I have room for my high profile memory on my biostar 990 FXE. Now in saying that, I would think that most MoBos have the same clearance from the socket, but if you have a non ATX board it could be smaller. As far as performance, I can never hear my CPU fan running and my temps are super cool.
The Hyper 212 Evo will definitely cool better than your stock cooler. For the height clearance: The height of the heatpipes to the fan is 37mm so it would be best if your ram is under that... I am not sure of how tall your ram is so I can't really tell you if you would get clearance...
Pictures of Dimentions Here:
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
how would the cooler master hyper 212 evo perform with the amd fx 4100 stock fan would there be clearance for corsair vengeance ram too
and what case? clear the RAM, but wont fit in the case?...
airdeano
Good point. Lots of people overlook this. This would BARELY fit into my Shinobi. And it's wider than a lot of more inexpensive cases.
Always check the height of the cooler against your case clearance.
This is my case with 4x4gb of RAM and a Hyper 212 Evo cooler.
The RAM stick closest to the cooler is just barely touching it, with no space in between, but is not being pressed against it.
Feel free to ask me for any advice, and I may ask for yours too. I'm an otaku. =)
Steam: hiddenshadow8
Skype: phantom8258
