Hi guys this is my first post on the forum so hopefully I’m doing it in the right place.
I enabled resizable bar on my pc after doing a fresh windows install and all the necessary driver and bios updates. Doing this caused my nvme drive to stop working correctly. I initially thought the issue was with the drive because I was having minor issues with a couple of games crashing before I enabled resizable bar and it wouldn’t start a crystal disk mark test. Eventually I turned off resizable bar and it started working with no issues.
hopfully this saves some people the time that I wasted and I hope it will be fixed in future bios updates.
specs- Msi 3070, strix x470, 5600x the nvme is we blue 1tb
https://linustechtips.com/topic/1334480-resizable-bar-problems/
  • 1 month later...
