Need help (Cooling)
Go to solution Solved by AdamBGames,
7 minutes ago, thePmSquare said:
Budget (including currency): N/A
Country: India
Games, programs or workloads that it will be used for: Cyberpunk, RDR2, MFS, etc
https://in.pcpartpicker.com/list/NdWTfP
^ these are the parts that i think will work for me...i don't know how to cool the PC such that CPU doesn't go above 90 C at extreme loads over long periods. noise is not an issue for me. i have never water cooled or used an AIO before.
Thanks a lot in advance 🙂
The AMD CPUs are fairly good in terms of thermals, something like a Noctua U12S will be fine.
Country: India
Thanks a lot in advance :)
https://linustechtips.com/topic/1334352-need-help-cooling/
Country: India
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/1334352-need-help-cooling/#findComment-14704676
