I want to build a pc from zero (laptop user) that would be able to run the lastest AAA games at 1080p capped at 144fps (1080p 144hz monitor). Budgetwise around 1k euros but give me your ideas even of they exceed that goal mark (ofc the cheaper the better). If you can recommend a build or give me a link I would be glad. Thank you very much.
https://linustechtips.com/topic/1334025-help-building-gaming-pc/
For a BYO pc, it will be hard to get it under 1k because of GPU prices. Would you mind having a pre-built? I can post some links to some good ones if you want. Its really the only way you can get a GPU unless you want to camp out at Micro Center, which is how I got my card.
Yeah I dont mind giving me some prebuild ones.
Gaming PC:
CPU- Intel Core i5-10400 (planning to upgrade when Alder Lake releases)
CPU Cooler- be quiet! Dark Rock Slim up to 180W TDP
Motherboard- Asus ROG Strix B460-h Gaming
Memory- Corsair Dominator Platinum DDR4-3000 CL15 memory
Storage- Crucial P2 1TB M.2-NVME SSD up to 2400 MB/s
Video Card- MSI Ventus 2x Geforce RTX 3060 Ti OC
PC Chassis- Cooler Master TD500 MESH ARGB with Controller
Power Supply- EVGA 650w P2 (planning to upgrade to EVGA 80+ Gold 1k watts)
Rear Fan- Touchaqua Bitspower Notos RGB fan
Monitor- Acer EI272UR 2560x1440 144hz 4ms Radeon Freesync monitor
Keyboard- Logitech G810 Orion Spectrum
Mouse- Logitech G203 Lightsync (planning to upgrade to g502 HERO)
Controller- Xbox One Wireless Controller - Red
LaptopProcessor- Ryzen 7 4700U (8c/8t up to 4.1Ghz) with Radeon graphics, 16GB DDR4-3200 memory, 512 NVME SSD
