8 minutes ago, Harry1482 said:
Budget (including currency): £1500
Country: UK
Games, programs or workloads that it will be used for: No mans sky, other games of similar performance like fortnite and things.
My current parts list is: https://uk.pcpartpicker.com/user/Harry1482/saved/WQW6D3
If you just want to play no man's sky and fortnite at 60fps, you can save some money. Go down to the pascal gpu's and get a 1060+ or an AMD rx 570. You don't need 8 cores. 4-6 cores will be fine, so get a ryzen 5/i5 or even a ryzen 3.3300x. everything else is normal.
https://linustechtips.com/topic/1333761-my-first-ever-build/#findComment-14700484
saving money to be able to follow my dream of 3 three display setup might work, thanks for the input 😄
https://linustechtips.com/topic/1333761-my-first-ever-build/#findComment-14700526
