Budget (including currency): $700
Country: US
Games, programs or workloads that it will be used for: Light game (City Skyline), Deep learning intensive
Just need CPU, RAM, Cooling and mother board.
The current specs:
i7 4770K
32GB RAM
z97 Mother board
GTX 1080Ti
1TB NVME + 512 NVME
2x 2TB HDD + 1TB HDD
https://linustechtips.com/topic/1333642-upgrade-hackintosh-system/
Keep in mind that this means your current osx install WILL have to be redone. I'm looking into some boards that work well right now but the problem here is your 1080ti. All the boards that supported osx DO NOT support a low enough version where the 1080ti still works and vice versa.
Deep learning... On a hackintosh?
If  you use anything modern, you won't have any nvidia support, and amd is a no go for such tasks.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
