Need help finding software for a file
Solved by Murasaki,
Another software that appears to be using the ADI format is AOMEI Backupper. The best way to figure out which it is, is to use the program and make a small test backup to compare the file headers.
Vibora ·
Posted in New Builds and Planning3 -
4
3
Doctah ·
Posted in Peripherals1 -
5
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards3 -
Packhunter ·
Posted in Graphics Cards5
