Hi guys I am new to LTT and today I had some unusual Fps drops. Today I was playing Euro truck simulator 2 with graphics settings at max and it played fine for the first hour and a half then all of a sudden I noticed major FPS drops. So I started FRAPS and my Fps was 15-23 fps then I started GPU-Z and I was getting VRel/VOp  intermittently at the same time and my voltage was fluctuating a lot and GPU-Z recorded a minimum of 0.0000v for a second then it was back up. The GPU was only about 40% TDP It also seems to struggle running GTA V as it struggles to maintain 60FPS. It was doing it in 3D mark at first but then it settled down again. I have also had issues in the past with coil whine coming from the PSU then after I rebooted my system it stopped. It seems like my GPU is not running to it's full potential and is it possible that the PSU is starting to die. When I upgraded my GPU I Used DDU to make sure all my old GPU's drivers were gone and I am  running the latest drivers.
My specs are as follows
I7 6700K
RTX 2080 super
16GB DDR4 Corsair Vengeance Duel channel at 3200mhz
PSU is a Corsair hx1050 which is at least 5 years old not sure on total age as it was brought refurbished from scan.co.uk
the system is cooled by a water cooling loop. I checked my GPU temps and there around 40 degrees.
https://linustechtips.com/topic/1333168-possible-power-supply-problems/
When you have psu problem usually it would just crash.
