I'm looking for a ups for my gaming streaming rig with a small nas server I just need something big enough to power everything for a few minutes so I can shut it down properly incase of power outage Ive estimated about 1000 watts should be plenty I just want to double check before I buy one and it's not enough
The rigs 2700x with 2060 2 ssds and a hdd
3200g with a 710 gpu 1 ssd and 1hdd
Athlon x4 620 with ibm300 gpu
2 monitors I use four but I have two per each pc with the server hooked to the main stream monitor and just switch outputs when needed
https://linustechtips.com/topic/1333165-finding-the-right-ups/
1000 watts won't be enough to power all of that running at the same time.
You need at least 500w rated psu for each pc.
It will save you around 5-10 minutes.
https://linustechtips.com/topic/1333165-finding-the-right-ups/#findComment-14696654
