I need help please.......
32 minutes ago, abhay_2006 said:a upgrade so my parts will be
Ryzen 5 3500 ,ASUS rx 5600xt,16 gb ram
the GPU gains are not that significant, i would hold the GPU money for now and get yourself something like a 3060 at the later date.
33 minutes ago, abhay_2006 said:first - that do i have to change my motherboard and install the cpu or should i just use the old cpu by just taking the cpu out and installing the new one
You can install zen 2 CPU on a B350 board, but you need to update your BIOS. According to Asus, you gonna need BIOS Version 4801 or newer.
36 minutes ago, abhay_2006 said:second- can i just bring the same 8 ram stick and use the old and the new one in dual channeling
Depends on your memory. On intel side i would automatically say yes, but the combination of Ryzen practically begging for fast RAM and having a finicky memory controller means that both memory needs to be from the same brand, same speed, same timing, and same DRAM chip that works well with Zen CPU like Micron and Samsung. So make sure the manufacturer of your memory only uses 1 DRAM supplier or else i would say to get a new set of 16gb for maximum performance. But if you cant afford to make said research (or afford an entirely new 16gb kit) the benefit of both dual channel operation and more capacity is still there.
