Hi Guys,
I am fed up with my crappy power supply.It has many problems, many of which I will not go in to, with many of the issues being related to cable management. Can you recommend the cheapest reliable power supply that is modular, will fully power the parts listed below, has long cables (as my current power supply's cable are not long enough to rout behind the motherboard to the top 8 pin connector), and not burn down my house. As of now, I have a 660ti, but I plan to add another fairly soon.
i-7 3770k
H100i
Intel DZ77BH-55k
16 GB 1600 MHz Vengeance RAM
660ti
Disk Drive
1TB Seagate Hard Drive
One Intel SSD
Fan Controller and a total of 6 120mm fans (2 of which have led's), and 1 140mm fan
All Needs to fit in a CM Storm Trooper Full Tower
I think that is all you need to know, but I am not sure if I am forgetting something, so just tell me if I am.
Thank You In Advance
My Rig: | i7-3770k @4.9 GHz | h100i | Intel DZ77BH-55k Mobo | 16GB 1600 MHz Vengeance Ram | GTX 770 4GB x2 (SLI) | Acer 21.5" 1080p Monitors x3 | 1TB WD Black x2 (In Raid 0) | 256GB SSD | Quickfire TK Blue | Razer Deathadder 2013|
Surfing it up in Huntington Beach, USA. Find me on Steam (my username is /r/buildapc).
https://linustechtips.com/topic/13324-recommend-a-power-supply/
The Corsair CX500M is going to be your best option.
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
https://linustechtips.com/topic/13324-recommend-a-power-supply/#findComment-142994
Yeah, Seasonic is my favorite for PSUs (I'm rocking a 660XP2), but Corsair is my second pick. In this case, I suggest the CX500M because it's currently a bit cheaper than Seasonic's offerings (e.g., the M12II 520). Cooler Master's offerings might also be considered, but the Silent Pro M2 620W is way more expensive than you need to go.
https://linustechtips.com/topic/13324-recommend-a-power-supply/#findComment-143015
I can't stand coolermaster psu's, they just look terrible!
https://linustechtips.com/topic/13324-recommend-a-power-supply/#findComment-143043
Looks aside, I haven't heard too many complaints about Cooler Master's units. Where I work, I sell a lot of PSUs and, while OCZ units are constantly getting returned, the Cooler Masters, like the Corsairs, don't come back. I only suggested Cooler Master because of that and because s/he has a Cooler Master case.
https://linustechtips.com/topic/13324-recommend-a-power-supply/#findComment-143087
I recommend any PSU from Corsair, any 600w PSU.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/13324-recommend-a-power-supply/#findComment-143431
I would recommend the SeaSonic X Series X650 Gold psu.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/13324-recommend-a-power-supply/#findComment-145696
I don't know why everyone else is recommending 650w or below PSUs but since you're gonna be adding another 660ti, I would suggest either an Ax750/760(Full modular) or HX750(semi modular)
Both are 80+Gold
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
https://linustechtips.com/topic/13324-recommend-a-power-supply/#findComment-145714
Both are 80+Gold
That's a really good point. I had completely forgotten s/he was planning on adding a second video card. In that case, Smithaveryb, you might want to consider something like the Corsair CX750M.
https://linustechtips.com/topic/13324-recommend-a-power-supply/#findComment-147178
