I need help remembering....
Go to solution Solved by HeyCya,
Pretty sure this is the video:
It's called Windows 10 Ameliorated: https://ameliorated.info/
Hope this helps!
My first post.
You know when you get agitated when you think of a song but can't remember what it is called. Well I'm having that experience right now but with something Linus Tech Tips related. I remember in one video and I can't remember if it was a sponsor or not where Linus talked about a project which basically supported a de-bloated version of Windows 10 ISO. It would turn off other features too such as Cortana, updates etc. I cannot remember for the life of me what this project was called. I'm pulling my hair out.
Hope someone can figure this out.
Xployt
https://linustechtips.com/topic/1331857-i-need-help-remembering/
Hope this helps!
SPOT ON!!!!!! Wow! Yeah that's it.
Thanks for saving my hair @HeyCya
Definitely impressed with the activity of this forum, maybe I need to stick around more often as I am a big fan anyway. Are there any benefits to being forum members?
